SHARP MX7500N code F0-86
  • obexi8
    • Apr 2016
    • 11
    Hello Everyone,
    I have a sharp MX-7500N machine and I suspect I am having an issue with the finisher tray. What happens is that when i lift both the trays up to the top i.e. finisher tray 1 and 2 and power the machine.
    The trays go all the way to the bottom and makes a clunk sound repeatedly when trying to move up back to home position. I have tried reconnecting all the cables on the controller board, not sure if changing the tray motors can help.
    Please I need help on solving the issue. thank you
  • chatkal
    • Aug 2015
    • 47
    Re: SHARP MX7500N code F0-86
    It can be something wrong with the home position sensor. Check it. It's right above the load tray when it's in normal position, in the middle. Check the sensor in Sim 3-2, FNS114
    • obexi8
      • Apr 2016
      • 11
      I will be sure to give it a check when next i visit the customer, thanks for the support
      • gregoryrbrts
        • Mar 2017
        • 33
        Originally posted by obexi8
        Hello Everyone,
        Check to make sure that both finisher trays are level, if they are not it will bind up and you will get that code.
