Admin password reset Sharp MX2650
  • osamu
    • Jul 2017
    • 4
    [Misc] Admin password reset Sharp MX2650
    How do you do, isn't there a person doing a way of a reset of an administrator password of MX2650 series of SHARP? I know a reset of MX2310 series. Thank you very much.
    By machine translation, excuse me.
  • Elmo
    • Feb 2010
    • 541
    Re: Admin password reset Sharp MX2650
    On the Main pub there are two very small switches. Turn on #1 then u can get to sim 24 to reset admin.
    I Used To Live To Fix Things Now i Fix Things To Live
    • ruben
      The New Guy
      • Oct 2012
      • 1204
      Sharp have been moving away from the old dip-switch resets, for the newer models you have to request a password reset directly from Sharp. They will issue you with a reset code that can be used on the copier's web manager.
      • osamu
        • Jul 2017
        • 4
        Thank you very much. You can not be reset at the side of the machine? A mortifying
        • bilyahn
          • Dec 2006
          • 1455
          Not sure if this applies to you but was also told at school if you have a data security kit installed you cannot reset the admin password period on the newest generation of color machines.
          Good luck.
          Bil
          • mojorolla
            The Wolf
            • 2551
            See photo of the reset dip switch. It is very tiny, the picture does it no justice. If you look at the MFP pwb metal cover, there will be a square hole where this switch is located on the MFO board.
            • sharptech
              • May 2011
              • 40
              On these new models you will have to contact Sharp to get the password reset. Sharp will give you a code that needs to be entered into the machine. No more dip switches.
              T.G.G.
              • Manten
                Hi,
                this thread was really useful for resetting my MX2310u using the dipswitches trick mojorolla described. The only difference was the location of the dipswitch on the PCB, so I added a picture to clear that out.
                The dipswitches were actually reachable without having to remove the metal cover, which I discovered only after removing it, as it goes....
                Good luck!
                • osamu
                  • Jul 2017
                  • 4
                  Hello eventually it can now be used by using a backup of the HDD. Thank you
                  • xordi69
                    • Jun 2010
                    • 200
                    if you clone or replace the mSATA from other mx-2650, password "admin" again
