Sharp MX-2300
  • doicho
    • Nov 2011
    • 13
    Sharp MX-2300
    I have problem with two copiers Sharp MX-2300N. When I printing or coping color on the page have random vertical thin color line.
    I change everything without power supply board.20171027_115344.pdf
    Re: Sharp MX-2300
    I change everything without power supply board.[ATTACH]38022[/ATTACH]
    did you clean the laser lens? how about the transfer belt/roller?
    charge roller/corona?
    not really sure what you mean by " I change everything without power supply board "
    • Ratchet2501
      • Mar 2017
      • 206
      Re: Sharp MX-2300
      Looks like the cleaning blade to me but I could be wrong based off paper orientation.
      • doicho
        • Nov 2011
        • 13
        Re: Sharp MX-2300
        I get parts from other copier - transfer, drum, laser unit, main boards without power board and HV board.
        • moose55
          • Mar 2017
          • 143
          Re: Sharp MX-2300
          If you are running LTR-R (short edge) you may want to rebuild the K PCU. Looks like drum/cleaning blade?
          The Moose is loose!!
            Re: Sharp MX-2300
            but it's a magenta line... i would look at magenta drum
            • austonrush
              Sharp & HP Tech
              • 234
              Re: Sharp MX-2300
              You have 2 lines on your image. I'm going to assume your paper orientation is letter-r (short edge fed)
              Red line (rebuild your magenta drum)
              yellowish brown line (looks like primary transfer cleaning blade issue) Pull the belt and inspect it. You should see it.
