Virgo (4111-5141) Web Stalls
  • mojorolla
    The Wolf
    • 2606
    [Misc] Virgo (4111-5141) Web Stalls
    Hey all, I have seen this issue a few times as these machines age. Hopefully the attached bulletin will save someone a few parts...and a few grey hairs.
  • boutn
    • Jun 2016
    • 547
    Re: Virgo (4111-5141) Web Stalls
    We had lots of problems with noise and web stalling with the mx4141/5141
    Found out after a few interventions, that the new fusers we had placed during maintenance started stalling.
    Problem was with the fusers themselves, not the machine.
    After bending a little axle from the webcleaning gears, noise and stalling went away.
    These were brand new fusers btw, and we only had the problem with the MX511FU.
    Probably manufacturing errors.
    • mojorolla
      The Wolf
      • 2606
      Yes, I would say at least 80% have been Virgo 2 machines (4151-5141)
      • boutn
        • Jun 2016
        • 547
        If you try to move the webcleaning by hand, and this doestn work, means that the fuser isnt right.
        If you try this on a fuser that is correctly manufactured, you can move the webcleaning fairly easy...
        • copyguy1
          • Jul 2011
          • 142
          sharp knows of this issue both the ones from NPC and sales has this problem.
