DV Unit losing magnetism
  • WhoDatXLIV
    • Mar 2017
    • 14
    I've got a MX-7040 that has a line on the mag roller where the developer is no longer sticking. It's happened on several other machines as well. What causes this?
  • Luke123
    • Nov 2017
    • 22
    Re: DV Unit losing magnetism
    Have you looked to see if you have anything stuck at the dv doctor blade?
    • ZOOTECH
      Senior member of CRS
      • 3375
      Is it a rotational void, or front to rear void. If rotational, the previous post has your answer.
      • WhoDatXLIV
        • Mar 2017
        • 14
        It didn't appear that it did. And the 4101 I had this on as well still had it after a pm.
        • harleyrider
          • Oct 2011
          • 348
          What Luke said
          • ntbann
            • Jan 2012
            • 628
            Your DV doctor blade is built up. If you look on ctn you will find a post by Black Cat where he makes a hook from mylar to get the chunks out.
            • JLSam
              • Jun 2015
              • 605
              [ATTACH=CONFIG]38133[/ATTACH]
              I've seen this, yeah, exactly as Luke said. There is most likely something stuck on the blade. Usually some toner accumulation that has mildly hardened into a little clump and is now stuck there in between the Mag-roller and Blade.
              Solution: ALWAYS vacuum the inside of the DV unit when it's emptied.
              • Luke123
                • Nov 2017
                • 22
                If your getting this on several machines, and after a PM, then the developer units are not being clean well enough. I would double check the method that is being used to clean the dv units on the PM's. If not cleaned very well you will get this white line issue from the loosened/harden toner/dv that builds up on the ends, and then will lodge in the dv doctor blade giving you your "DV losing magnetism". Really what you are getting wake created by the build up, and not a lose of magnetism. If you lose magnetism you would have a much bigger problem.
                • JLSam
                  • Jun 2015
                  • 605
                  Originally posted by Luke123
                  If your getting this on several machines, and after a PM, then the developer units are not being clean well enough... If you lose magnetism you would have a much bigger problem.
                  Exactly right. [emoji106]
                  Sent from my ONEPLUS A5000 using Tapatalk
                  • WhoDatXLIV
                    • Mar 2017
                    • 14
                    Thanks guys. Found the tool blackcat created and it worked beautifully. Looks like I need to speak with my pm guy now... smh
                    • ZOOTECH
                      • 3375
                      With an older machine the foam seals start to deteriorate, and if using a brush or vacuum to clean, the foam will find it's way under the doctor blade and travel to a different area if not removed.
                      • Hansen88
                        • 1068
                        So how do you guys clean out your developers on a pm. Unless you remove the blade and the augers I dont think the vacume does much on the inside. In the shop after I clean it out with vacume I will blow out the inside of the unit. Out in the field to me it does not seem like you can do a great job on cleaning it without taking it apart. Maybe you guys are taking them apart. Just for my knowledge to find a better way, how do you guys clean them in the field.
                        • jp74msj55
                          • Oct 2014
                          • 149
                          Where can i find Black cat post with mylar rig, thanks.
                          • Cipher
                            It's not easy being green
                            • May 2006
                            • 1309
                            Most our customers cannot tolerate a toner vac being on due to the machines being in open plan offices.
                            So I empty them manually.
                            I use a little 1/2 inch paint brush to get in the hard to reach places.
                            Then I keep gently shaking and tapping the dev unit upside down while rotating dev roller with my finger.
                            I just keep going until there are no iron filings left when I rotate the mag roller.
                            Takes me about 10 minutes per dev unit.
                            I've never had any problems after a dev change with void areas.
                            When I take a new junior tech out with me on a PM I always like to ask them to empty out a dev unit without giving them any additional tips.
                            It's good training as most of the time I can demonstrate just how much old dev still remains in the unit after they proclaim it's empty.
                            • blackpanther
                              • Nov 2017
                              • 16
                              There is a tool from Sharp to rotate the dev roller true the gears, so you don't have to use you're finger. It is very handy.
                              It is called the "DV HANDLE" and the parts code is "UKOG-0341FCZZ"
