Get a call from IT dept from a client. They can't scan. They spent hours they said, so I took a crack at it. With the correct set up Execute test said: 'Connection to SMTP server test succeeded.' EXCELLENT I said. IT goes to scan, "Selected servers not found". WTH.
So after about 20 minutes, I'm screaming because setting up their Office365, should be easy. I try my GoDaddy settings. Works beautifully, e-mails without any drama. (Thank you GoDaddy, for your simple set up).
Now... get this.. They have a 4101, with all the same options. We compare, all the settings are the same. So just in case, we CLONE everything to the 3100. All the settings from the 4101 go to the 3100 machine. We get the "SMTP Server test succeeded". IT guy on site goes to scan, "servers not found". I almost break my mouse. I tell them use our GoDaddy e-mails server settings till further notice.
I tell my boss, he purchases OFFICE 365. After a minute these settings work great:
Office 365
Primary Server: smtp.office365.com
Port: 587
Secure Socket Layer: On
Reply E-mail Address: [Username]@[DomainName].com
SMTP Auth: ON
Username: [Username]@[DomainName].com
Password: [Password]
NO, you don't have to use the "<" ">" anymore. That sharp bulletin out of date.
Go Daddy
Primary Server: smtpout.secureserver.net
Port: 80
Secure Socket Layer: OFF
SMTP Auth: ON
Anyway, I just wanted to vent my frustration. I have no idea why 365 is not working on that machine. I checked the ports... but then again it doesn't matter because it's cloned from another of their good sharp machines. Sigh... any ideas?
Office 365
Port: 587
SMTP Auth: ON
Go Daddy
Port: 80
SMTP Auth: ON
