E-mail going to Junk.
  • JLSam
    • Jun 2015
    • 605
    This month consists of a lot of e-mail problems for me lately. So my client has windows 10 outlook. They said that the e-mail is going to junk folder [quarantine], and he has to release it. I add the e-mail to "safe senders" and domain to the list. I use the "e-mail status and alerts" feature to e-mail to the end-user, and it goes through just fine!
    I advise end user to use the scanner to e-mail to himself, but it doesn't go through. How can this be?
    It can be a firewall problem, because e-mails go through in Status and Alerts.
    Can't be closed ports too, because e-mails go through in Status and Alerts.
    I am thinking it's an application issue, but in status and alerts uses the same e-mail as you would in the address book for scan to e-mail.
    I'm open to suggestions.
    "NOTE: Sharp MX-2600 with the latest firmware, no DSK"
  • mansart
    • 852
    Re: E-mail going to Junk.
    If I understand this correctly.....
    • machine can send status to bob@usa.com and Bob receives in his IN box
    • send an scanned PDF to bob@usa.com and Bob finds the email in Junk Folder
    If the above is accurate then....
    • machine is sending fine, check the scan job log and look at send results
    • Bob's email system is somehow tagging email as junk,
    Check system time on copier, make sure it is accurate, sometimes a time stamp way out of sync with real time will cause issue
    Try to send scan with attached JPG instead of PDF
    • JLSam
      • Jun 2015
      • 605
      You understand, you are correct.
      I will check time and date later today when I call him back. Thank you.
      Sent from my ONEPLUS A5000 using Tapatalk
      • guitar9199
        • Sep 2016
        • 1100
        I've seen some situations where the "Subject" line of the email will automatically forward an email to the Junk Folder. The usual culprits are the words "Attachment" or "Scanned/Scan", and removing those trigger words should help.
        • PrintToPDF
          • Oct 2015
          • 27
          Also, check E-mail inbox through the web portal of the email provider. Possibly not Outlook itself, but the email provider spam filters. I have noticed recently that it has been happening sending to some office 365 accounts.
          • sck
            • Mar 2009
            • 20
            Sometimes its helped adding sender name and replay address under system-settings -image send settings - scan settings
            Default Sender Set:
            • ovid
              • Aug 2014
              • 9
              We have noticed here that adding a "less than" symbol before your reply address and a "greater than" symbol after it has fixed this issue.
              Example:<youremail@address.com>
                • 8228
                I do not know about Sharp copiers but try changing any default settings away to something else.
                Such as MFP- Mac Address numbers to MFP-customer under TCP-IP settings
                Such as MFP-Mac address numbers to MFP- customer under NetBios name
                Such as Email tab Default Body String to "No Reply Email Address"
                Such as Email Default subject line to MFP-customer
