It started out as a c1-10 error code after putting in a drum and drum mkit...
found out the drum got stuck on the new red felt...
dislodged drum... then put a little toner on the felt to grease things along...
in the process... of fixing a harness got broken...
(used a pin hook, stripped cables and stuck it all together... it works but looking for a permanent fix)
I am now looking for the harness that connects to the part that has the little lamp on it
dl pwb unit
CPWBF2062FCE2
I believe thats the part... the part that has the one screw that you need to take out before you can take out one of the screws to take out the drum unit...
the harness I am looking for is the one that plugs this little led board into the rest of the machine... it has a brown and grey wires...
admittedly not a good picture... but it would normally sit behind plastic bar with the holes in it...
any help is appreciated...
dl pwb unit
CPWBF2062FCE2
