MX-C300W screen hanging on startup (please wait)
  • joe_vanacker
    • Dec 2016
    • 28
    Hello,
    we have a sharp mx-c300w which doesn't start.
    the web page is accessable and printing works as well.
    the screen keeps hanging on please wait and does not come on the copy screen.
    there is no button that is responding.
    i replaced the mfp pwb without success.
    regards,
    Youri
  • Ratchet2501
    • Mar 2017
    • 206
    Re: MX-C300W screen hanging on startup (please wait)
    Any idea if the firmware was updated recently? I have seen cases where cherry picked firmware and not complete updates can cause this. One other angle would be if the network is sending it a bad job?
    • copyguy1
      • Jul 2011
      • 142
      Also may want to try a SD card or the HDD
      • joe_vanacker
        • Dec 2016
        • 28
        the firmware is up to date
        • joe_vanacker
          • Dec 2016
          • 28
          in this version there is no hdd or sd card
          • mojorolla
            The Wolf
            • 2570
            Sharps boot in this order:
            MFP pwb
            SD card
            HDD.
            If machine has an HDD unplug it and see if you can get it to error out with E7-03. If you can generate that code, MFP and SD are working properly.
            • joe_vanacker
              • Dec 2016
              • 28
              MFP pwb
              SD card
              HDD.
              thanks for the reply but this machine has no sd or a hdd on board..
              • boutn
                • Jun 2016
                • 537
                FYI...
                turned out to be the LCD PWB Unit
