MX-C401, E7-11 code...
  • Oystercopy
    • Oct 2009
    • 623
    So, it says "white shading correction".. is this something to do with the optics/scanner, maybe being dirty or unable to read the white strip?
    Or something more sinister? Customer is 50 miles away, so might like some heads up!
    Thanks in advance.
    OC
  • dwarf
    • Oct 2012
    • 168
    Re: MX-C401, E7-11 code...
    there is a simulation(62, I think) that is a shading simulation...
    • spanky
      • Sep 2012
      • 468
      63-2
      • Oystercopy
        • Oct 2009
        • 623
        Originally posted by spanky
        63-2
        Guys, does this mean that the optics are dirty, and that I should (maybe) be adjusting for that? And I don't know how to get into simulation on that model. Can you help answer these questions?
        • moose55
          • Mar 2017
          • 143
          It all has to do with white plate, optics, CCD. If you have never tried to tear into the optics on one of these machines, then you will soon find out why a new scanner is only a couple hundred bucks. I would try sim 63-2, cleaning white plate, etc. before attempting to crack open the optics. The SCU PWB may be another possibility. What I am trying to say is this, if you attempt to get into the optics/CCD just make sure you have minimum of a couple hours. More than likely 3-4 hours, and have a new scanner bed with you. Sharp, as with any other manufacturer, always has that "screw the tech" machine out with every generation. The 402, 401, 311... are these machines. My experience has been that once you attempt to access the CCD/scanner, you will break the plastic tabs that hold it together. Oh, and did I mention that you have to remove the scanner bed to do this? Most orf the time the E7-11 is completely random. When it is not try everything else before the scanner itself. Just my $.02 worth....
          The Moose is loose!!
          • dwarf
            • Oct 2012
            • 168
            clean the optics...don't tear into anything...run 44-2/6/26 and and 46-24/74...then run the shading simulation... # - * - c - * will get you into sims...
            • mojorolla
              The Wolf
              • 2627
              These first run 401 machines are notorious for the glue holding the white strip to yellow with age. Unfortunately for us techs, it is on the underside of the platen glass. There is also a shading sheet required for proper calibration on various models. You can remove the ADF and scanner unit to crack open the scanner unit. I have found this to take about an hour in and out, but results will vary. As mentioned, this is not a fun process.
              • Waylon
                • Sep 2010
                • 26
                Another "Quick fix" try is to oil the optics rail. We have learned over the years that sometimes the scanner does not jog back an forth quick enough when it initializes and can cause the E7-11. we have avoided getting into the optic box on a few machines by drilling a hole in the scanner box over the optic slide rail, move the scanner to the other side first with the simulation, then apply a little oil to the rail and run the scanner. It will not work every time, it depends on what is causing the problem, and we like to try everything before we remove the scanner box. ALSO, the other day problem was caused by a broken tension spring bracket for the optic drive belt. Was easy to see under the glass but had to replace the optic box.
