mx-3070 family e7-80
  • 1090tech
    • Jan 2018
    • 8
    This new line of mfp's has replaced the sdcard from the older models with a msata card but these seem to be just as unreliable as the sdcards. E7-80 errors, which the manual recommends fixing by replacing the scn-mfp board, can usually be fixed by just replacing the msata card.
    It seems that problems that were caused by bad sdcards will now be caused by bad msata cards.
  • mansart
    • 852
    Re: mx-3070 family e7-80
    Save yourself a bundle.....download HDD Raw Copy Tool and a USB to IDE/SATA Adapter and copy data from SATA card from new or working machine. Then when you have a bad one just re write the image......it's not the SD card or SATA card that's bad its the software written to them.
    • OlliK1969
      • Nov 2016
      • 311
      New firmware v6.51 or higher
      • 1090tech
        • Jan 2018
        • 8
        Does the msata card fit in a sata connector?
        • mansart
          • 852
          No you need a USB to IDE SATA adapter
          https://www.amazon.com/StarTech-USB-...h+sata+adapter
          • mojorolla
            The Wolf
            • 2627
            As suggested in an earlier post, update the firmware. One version was specific for curing E7-80 and E7-90 errors....
            • tonasis
              • Oct 2015
              • 10
              Hi there
              This links to an adapter I already have, for 2.5" and 3.5" HDD's, this won't work for the Msata cards in question.
              Has anyone found a suitable adapter to do the job? I've googled around, but struggling to find one at the mo
              Tony
              • mickj
                • Apr 2015
                • 33
                This is the one I use
                ORICO mSATA Hard Drive Enclosure
                • mansart
                  • 852
                  Sorry about incorrect link..... tonasis is correct
                  • tonasis
                    • Oct 2015
                    • 10
                    No problem Mansart!
