Problem installing Pantone on a MX-6240
  • Hansen88
    • 1066
    Hello, I am trying to install the pantone system on a 6240. First I had trouble installing the LUT files. I found a bulliten where it said the instructions were wrong and to install the LUT files in the spot color table setting section. I did that and it took. So now in the spot color table setting it shows the color table being there. All now seemed to be going good. Now the next step is to run the check file and get the printout showing that it is installed. When I try to print the file the machine sounds like it is gonna print but then nothing happens. In the spool ti says rendering and the machine acts like it is locked up. I installed this on a different model before and it all worked as it should. I dont know if I am missing something or what my problem is. Looking for any help or suggestions. Thanks
  • Hansen88
    • 1066
    Re: Problem installing Pantone on a MX-6240
    Well after deleting the lut file and reinstalling it for about the 10th time it for some reason worked and printed out the Pantone table installed confirmation print. So I should be good now,after messing with this for hours.
