Data Security Kit MX-FR30U
  • Jack79
    • Jul 2014
    • 312
    Hi
    How can I uninstall or disable data security kit MX-FR30U from Sharp MX2610N?
    Regards
    Jack
  • driving lots of miles
    • Jun 2016
    • 399
    Re: Data Security Kit MX-FR30U
    From what I understand it cannot be uninstalled without changing the main boards
    • Sam Tofu
      • Dec 2007
      • 130
      Expensive hassle to reverse data security. Also expensive if just one data eprom goes down. Have to replace full security kit or replace all the Main boards.
      • mickj
        • Apr 2015
        • 33
        Why would you have a need to ?
        but once its fitted it can not be removed with out replacing all the boards
        just have to remember to use DSK firmware on up dating firmware
        • Jack79
          • Jul 2014
          • 312
          I suspected that security kit will not be easy to uninstall. I was told that the machine works slow because of security kit (data are erased all the time). I checked and found memory clear option available from kit and this cure the problem.
          Thanks for your replies guys.
