mx-3070n e7-80
  • dcooper
    • Nov 2014
    • 37
    mx-3070n e7-80
    I have a mx-3070n in which I'm getting an error code E7-80 and E7-90 about every 2 weeks. I update the firmware using the emergency update
    procedure with a jump drive with the firmware from sharp's webpage. I see a thread stating you can download HDD RAW COPY TOOL and a USB to
    IDE/SATA ADAPTER and copy data from SATA card from new or working machine. Does anyone know the procedure to copy the data from a new or working machine? I want to do this procedure but i'm not sure exactly how to do this. Thanks for your help
  • mickj
    • Apr 2015
    • 33
    Re: mx-3070n e7-80
    sim 56-2 to back up both
    • mojorolla
      The Wolf
      • 2584
      Re: mx-3070n e7-80
      Check your firmware as this can be caused by older firmware.
      Current level is V7
      • bilyahn
        • Dec 2006
        • 1470
        Re: mx-3070n e7-80
        Had these error codes on a couple of 6070 machines. Updating to a newer firmware only worked for a short time, both machines finally went dead with just the power LED icon flashing requiring the mSata chip to be replaced.
        Good luck.
        Bil
        • mickj
          • Apr 2015
          • 33
          Re: mx-3070n e7-80
          Same here on MX5070N
          I how do a back up of the M-Sata boards for each new model, and keep a copy on my laptop and on the server at work just in case I need to replace one out in the field
          • mansart
            • 852
            Re: mx-3070n e7-80
            mSATA to USB
            HDD Raw Copy Tool
            • sharphead
              • Aug 2009
              • 285
              Re: mx-3070n e7-80
              Appreciate the info, where do you guys buy your blank cards? or what spec are they.
