Sharp MX4100n H5-01 after trouble cancel...
  • Service@PRT
    replied
    Re: Sharp MX4100n H5-01 after trouble cancel...
    Thanks guys.. it was the shutter who has a problem. The solenoid is bad enough for the shutter not to open. So i just changed the solenoid and all good.
    Sent from my HUAWEI VNS-L21 using Tapatalk
  • niceville318
    replied
    Have you tried updating or re-flashing the firmware?
    You say you're getting blank pages. So the mfp is not jamming anymore or is it still printing blank pages and jamming at the POD1 sensor?
    With this model I've had to disconnect the mother PWB and PCU PWB, reseat all connections for a similar problem. good luck
    replied
    Originally posted by Service@PRT
    No color nor black print out.. in either copy, print from sc or that comes from computer, so its totally blank pages that is coming out of the machine.
    i'd clean the contacts for ALL colors on TBelt... if you do a stop print is there image on the drums?
  • JLVisser
    replied
    Yep checked that one... And its all good now. Thank you again.
    You're welcome!
  • Service@PRT
    replied
    Originally posted by JLVisser
    There is a solenoid that opens the shutters. That solenoid is probably bad. You can test it with Sim 6-1, LSUSS.
  • JLVisser
    replied
    Thanks.. it was the shutter.. in someway it is stuck and not opening.
  • Service@PRT
    replied
    You say there's no toner on the drums? Sounds to me like your shutter solenoid is not opening. How did you test to see if the shutters open all the way? Remove the black shutter temporarily and see if you get image.
  • Service@PRT
    replied
    i didnt say that there is no toner.. toners is new and Genuine, all of them... i will check about that shutter test when we got there today.
  • JLVisser
    replied
  • daileyrobn714
    replied
    Originally posted by clark
    On top on the drums in the transfer unit. The power supply will be in the back of the machine in about the middle of the machine.
    Ok, thanks.oops I commented on the wrong model. Sorry about that.
    Sent from my SM-G930V using Tapatalk
  • clark
    replied
  • daileyrobn714
    replied
    sounds like the power supply for the main coronas is bad. Don't know how to check it.
    Inside the processing unit it rest above the drum
  • clark
    replied
  • Service@PRT
    replied
    also check the black developer unit for developer in case you were having dv pull. Did you try color copies and see if there was any color ?
  • clark
    replied
