I need a Mx-Pk11 post script for a sharp mx3115. Thanks
Need MX-Pk11
Re: Need MX-Pk11
the pk11 is a softwareoption .
your local sharp dealer can help you .
if the pk11 is for a machine registered , there is no way to transfer to another . -
Re: Need MX-Pk11
hello ,
you can buy at different webshops these option .
Only you need is the applicationnumber on the sheet , what is in the box .
then you may collect the exact modellname , the serialnummer .
if you have all informations :
Modell :
Serialnumber:
Applicationnumber from the sheet:
Option : in this case mx-pk11
Send me a private message and i will give you the serverinfo and the logindata and a little information for doing .
the you can create the produktcode by yourself.
michmichComment
