sharp Mx-m453n need firmware
  • armana2007
    • May 2017
    • 15
    hello
    I have an mx453 when I turn it on , it shows me that it need to upgrade . how can i get the firmware . I checked sharp website but it doesnt have that . please help me .
  • armana2007
    • May 2017
    • 15
    Re: sharp Mx-m453n need firmware
    Originally posted by armana2007
    hello
    No body have this . it for my customer and they need the device .
    • moose55
      • Mar 2017
      • 143
      I have never had a Sharp tell me that it needed firmware updated? If you look at what firmware version is on it< then you can determine if firmware needs upgraded. MX-M453N firmware is readily available on the Sharp-IDNC website.
      The Moose is loose!!
      • daileyrobn714
        • Jan 2018
        • 31
        Yes sir, never seen a sharp machine tell me it needed firmware. Interesting. If you go to Sharp indc you have to credentials to login
        Sent from my SM-G930V using Tapatalk
        • JLSam
          • Jun 2015
          • 605
          Never seen a Sharp Machine say "Needs Firmware Upgrade". Pictures would be nice.
          One more thing, some machines have a Data Security Kit installed in the machine. You need to make sure you update the DSK if it has it. If it doesn't, then the normal firmware for the machine. Find out if it has a DSK first.
          • armana2007
            • May 2017
            • 15
            It doesn't tell me that need firmware update . when I turn it on it doesnot boot . like the picture below .WhatsApp Image 2018-01-31 at 10.05.59.jpg
            • armana2007
              • May 2017
              • 15
              • Michmich123
                • Nov 2013
                • 24
                hey there
                these message is , you have switched a little switch on the controller . the name of the switch is "update on/off"
                switch it to off . then reboot the machine .
                if it is the same , look for a missing componet on the board .
                Flash-rom (named jup3 boot or main ) there are two of these
                memorycard
                it is also possilble , that the machine have lost the firmware . then you need the right on .
                dsk
                normal
                or dsk spezial ( then it is not possible to reflash the firmware, in this case you have to replace the Flashroms)
                michmich
                • armana2007
                  • May 2017
                  • 15
                  Originally posted by Michmich123
                  hey there
                  memorycard
                  dsk
                  normal
                  michmich
                  thank you . the device was working . the update switch is off . how can i update the firmware
                  • armana2007
                    • May 2017
                    • 15
                    hey there
                    memorycard
                    dsk
                    normal
                    michmich
                    Thank you guys . the flashrom had problem . I changed and update the firmware and the problem solved .
