Sharp mx m314
  • davebtech
    • Apr 2015
    • 176
    Sharp mx m314
    Loosing scan to email network connection after 15 pages. Any suggestions thanks in advance Dave
  • ivan123
    • Oct 2014
    • 54
    Re: Sharp mx m314
    What is a situation when you scan to email one page? Maybe somebody put limit for files, or mail is limited in MB.
    • davebtech
      • Apr 2015
      • 176
      Re: Sharp mx m314
      Connection scan of 15 or so pages and under works fine What do you mean by MB?
      • ivan123
        • Oct 2014
        • 54
        Re: Sharp mx m314
        Megabyte
        • davebtech
          • Apr 2015
          • 176
          Re: Sharp mx m314
          Megabyte
          Ever run into this before? Would adding more memory to sharp help?thanks Dave
          • ivan123
            • Oct 2014
            • 54
            • davebtech
              • Apr 2015
              • 176
              Re: Sharp mx m314
              Thanks on my way back there later will give it a try looks good thanks!
              • dsmith46
                • Oct 2016
                • 81
                Re: Sharp mx m314
                Also, while you are on that specific tab on the web interface, I would make sure that Mono2 is selected for both Scan and Email. Change the compression to High as well. These changes will help to keep the sizes down to a minimum. Making sure the Unlimited is set will help, but if their email server only accepts up to a certain size, then there is nothing more that you can do on your end.
                • davebtech
                  • Apr 2015
                  • 176
                  Re: Sharp mx m314
                  Working now ,Thank you!Set compression to high and mono 2.It was on unlimited.
