Failed - Network error chrome
  • nejcos
    • Sep 2014
    • 6
    [Misc] Failed - Network error chrome
    Hi, i am having trouble when doing storage backup and device cloning. From Chrome and edge it gives me error Failed - Network error, but on Firefox it works normal. Is there any settings i could do on Chrome to fix this. It is very annoying when doing this at customers who dont have Firefox installed on PC.
  • JLSam
    • Jun 2015
    • 605
    Re: Failed - Network error chrome
    It's designed to be used with internet explorer, not Edge. Use internet explorer.
    Good luck.
    • nejcos
      • Sep 2014
      • 6
      I tried on Internet Explorer, still no success. Gives me error. Tried it with many customers, solution is always install Firefox. Problem is when i dont have rights to install.
      • mttech
        • Mar 2014
        • 127
        On most of the newer machines you can use a USB drive and do these operations at the copier.
        • CopierShaman
          • Mar 2018
          • 6
          It's because most new browser now treat almost all site as non-secure unless it uses https and has a valid cert. Chrome is deeply involved in the development of this new feature. However, IE should have no problem getting the files. As long as you don't use InPrivate mode. Also, there's a general misunderstanding that MS Edge = MS IE. Their icons looks the same but they work differently. Make sure you are actually using IE and not Edge when trying to perform the backup.
          • mojorolla
            The Wolf
            • 2634
            If your PC is Windows 10, you almost certainly have Edge....
