MX-M354N DF jams
    • 15068
    MX-M354N DF jams
    I am working on an MX-M354N and when a document is fed through the DF it stops just as the lead edge hits the slit glass and shows a message on the display asking if you want to continue. It does this with every sheet fed, and stops at the same spot every time.
    I cleaned all the rollers and blew out the sensors I could get to with the canned air.
    I am not a Sharp tech and I don't have access to any Sharp bulletins as we have had these machines pushed on us because of the KonMin buyout of Pitney Bowes in Canada.
    Any help is greatly appreciated.
    Thanks.
  • spanky
    • Sep 2012
    • 468
    Re: MX-M354N DF jams
    What is the jam code?
    • Hansen88
      • 1085
      Usually to get to the sensors in that turn area you need to remove the feed unit from the doc feed shell. Also make sure the paper isnt catching on the slit glass assy causing it to stop there. Otherwise we would need a jam code to try for something more solid.
      • mansart
        • 855
        Go into SIM mode "#*C*"
        2-1 will check the operation mechanically, a doc feed free run, no jam detect
        2-2 will check the individual sensors
        Sounds to me like the actuator out of position......SPPD4 a likely candidate ....actuator gets pulled out of position when customer removes misfeed in reverse direction.
        • moose55
          • Mar 2017
          • 143
          This is one of the feeders that had the sensor problem. If you run a 22-6 you will probably have a SPPD2_N or SPPD3_N jam code. That would tell you witch sensor is the problem. The part # is VHPGP1A73A+-18.
          The Moose is loose!!
            • 15068
            Sorry for the late update. I replaced the paper path sensors and everything is working as it should.
            Thanks for the help.
            • Ratchet2501
              • Mar 2017
              • 206
              Stupid sensors anyhow
