Sharp MX-b402 print quality
  • tibbs
    • Aug 2008
    • 225
    Hello, I have a Mx-b402 that's printing light and on the left side of the paper I have replaced the drum and the toner but I am having the same issue.
    Also I have serviced and cleaned the machine.
    Thanks for any help.
  • JLSam
    • Jun 2015
    • 605
    Re: Sharp MX-b402 print quality
    Prints only?
    Have you tried cleaning the LSU window? You changed the drum, what about developer? Is your Transfer roller worn?
    • mojorolla
      The Wolf
      • 2606
      Pull the IT belt unit and look at the cam. This machine is notorious for the plastic frame breaking and causing this exact same issue...
      Also, check the fuser pressure is even.
      • moose55
        • Mar 2017
        • 143
        I would check all the other suggestions first, but I have had the LSU do this.
        The Moose is loose!!
        • JLSam
          • Jun 2015
          • 605
          I second this. Mojorolla is absolutely right about the Primary Transfer. I've seen that cam break quite a few times before too.
          Sent from my ONEPLUS A5000 using Tapatalk
          • jp74msj55
            • Oct 2014
            • 149
            Have had too many primary transfer belt units cause this even when they appear to be good!!!!!
