Sharp MX-2300 with Magenta background.
  • lenovos
    • Oct 2012
    • 140
    Hi I have an old Sharp MX-2300 that once every month or so leaves lots of magenta background and it is always magenta. What i have noticed is that after the machine goes through adjust copy quality the copies look fine.
    I have swapped out all of the consumables and firmware and reseated all connectors. What i have noticed is that the copier rarely calibrates itself. Today I reset the drum counters and as the machine was warming up it recalibrated. Most of the time if you turn on and off it comes straight to ready with out adjusting copy quality.
    MX-2615N_20180223_180835.pdfMX-2615N_20180223_180835.pdf
    Above are before and after examples.
  • copiertec
    • Jan 2016
    • 2199
    Re: Sharp MX-2300 with Magenta background.
    When you say changed consumables, does that mean you installed new developer, new drum and MK kit? Did you reset counters and manually go through the calibration procedure after changing these items? Looks as though something is shorting out.
    • lenovos
      • Oct 2012
      • 140
      Hi yes I did. I thought so too, but what I noticed is that those older sharps constantly wanted to adjust copy quality, this one does not. The clean copy is what you get after the machine runs through is calibration cycle. The copies will look fine for quite a while most of the time but a month or so down the lie it will come back'
      In simulation 44-28 the values were k bk ratio 40 I put it back to 20 same for value M.
      tt-13856 it was changed because of constant Print quality being adjusted messages.
      • copiertec
        • Jan 2016
        • 2199
        I don't think the box going or lack there off going into calibration mode is causing the issue. My reason for thinking so, is because it is just magenta, if it were related to a calibration issue, you would have more colors doing the same thing. If you have not changed out developing unit, try that, also I would re-seat, clean and check all connectors applying to the magenta developing unit and make sure they are making good contact, especially when the developing unit makes contact.
        The calibrating message all the time with the first series of color was a pain in the ass and customers would complain about it constantly. The pastel II series did not have that issue thank god, the only issue they had was cleaning transfer belt message which was resolved by tweaking a few #'s. So, not having that calibrating message, constantly, is normal for this box.
        • repn1999
          • May 2010
          • 310
          I have had to replace the mfp board and pcu board for a similar issue. looked like a blueprint once kind of, jet black background and then a color image printed on top from just a normal word document with a chart that was printed. this machine only did it once in a while and had just had all new supplies as well. I have also seen the same issue happen on another machine with magenta but basically the same thing. if you have another machine it might be worth swapping the boards. hotline thought it might be due to mfp/printer memory corruption when doing the jobs.
          • Eirik
            • Mar 2015
            • 9
            It seems like the Drum unit is overcharging and taking to much developer from DV Unit. You should replace Drum Unit and developer, not the DV Unit.
            • ivan123
              • Oct 2014
              • 54
              My experience is - Those lines should be from main charger magenta
              • Luke123
                • Nov 2017
                • 22
                I agree, and think you should try a new DV unit. As for the Calibration not showing up, You may want to look at SIM 26-53, and 54. That may give you some insight on that.
                • daileyrobn714
                  • Jan 2018
                  • 31
                  Hi guys, just reading over your comments. I'm wondering I'm having the same issue with my Sharp MX-B402 with constantly cleaning the transfer belt. I changed the transfer belt cleaned all sensors. My question is, is there something in simulation I can change to fix this?
                  Sent from my SM-G930V using Tapatalk
                  • copiertec
                    • Jan 2016
                    • 2199
                    This was an adjustment I made for the Pastel 2 series and it worked, hope it works for the frontier, Sim 51-2, select engine, select W and change from 40 to 30.
                    • daileyrobn714
                      • Jan 2018
                      • 31
                      Thank you very much !
                      • Paulm
                        • 69
                        If the other solution doesn't help. When in training we were told by instructor that when you get a lot of cleaning transfer belt messages (crazy as it sounds) is caused by roller timing. Mostly dirty/worn rollers but can be motors clutches or solenoids. Makes sense when you think about it. Although paper passes thru the delay throws the unit into recover cycle. The MX5110 series of machines had an issue with their LCC clutches causing that issue.
                        • daileyrobn714
                          • Jan 2018
                          • 31
                          It's funny you mention that, the rollers and tray one were bad I replaced them as well and so far so good. Thanks for all your help I do appreciate it
                          • lenovos
                            • Oct 2012
                            • 140
                            [QUOTE=daileyrobn714;596560]Thank you very much !
                            Hi I never did figure this one out, one of the very few I didn't solve over the many years that I have done this for a living. The copier is now retired after many years of service. I find this forum to be a great service and want to thank all of the great copier techs for their time and effort. My best to all of you.
                            Lenovos
