L4-36 on MX-7001N
  • Chunk_Blower
    • Mar 2018
    • 5
    L4-36 on MX-7001N
    Long story short, I replaced Paper Exit Cooling Fans in the delivery unit, Fusing Exhaust Fan as well as Fusing Cooling Fan. Also Tried a brand new PCU PWB.
    Any advice? Measurements are coming out correctly on Multi-Meter. Was gonna go with the Harness but it is unavailable from SHARP.
    L4-36 Fusing Suction Fan Lock
    Trouble content When the fusing suction fan is operated, the fan
    operation signal is not detected within the specified
    time.
    Section PCU
    Case 1 Cause Fan connector disconnection
    Check and
    remedy
    Check the harness and the connector between the
    PCU PWB and the fan.
    Case 2 Cause Fan does not rotate because of other trouble.
    Check and
    remedy
    Use SIM6-2
