Mx-c312 prints light on left side
  • Ratchet2501
    • Mar 2017
    • 206
    Thus far I have seen an f2-45 trouble code but that registered about two weeks ago. I have swapped the drum and dv assemblies. Cleaned the lsu, checked shutters, checked fuser which was recently replaced and tried calibrating a few things. No change in any of the listed items effected the lightened side. My dislike of the c line from sharp is becoming more pronounced the more I have to deal with them.
  • JLSam
    • Jun 2015
    • 605
    Re: Mx-c312 prints light on left side
    Got Scan Samples?
    • dsmith46
      • Oct 2016
      • 81
      If the LSU shutters are opening ok and the unit is clean, then I would check the secondary transfer roller assembly. I've seen where those springs get worn out and do not provide equal pressure to the page as it passes by the primary belt. You should be able to take off the secondary unit and stretch the springs out a little. I would also check the primary belt unit.
      Hope this helps!
      Dustin
      • Ratchet2501
        • Mar 2017
        • 206
        Well, Ive been trying to upload the file since 7 am this morning but no dice. It's the K side of things that's faded. All other systems seem fine. Beginning to think lsu but I dont see anything wrong with it. Going to try cleaning connections and see where that gets me. If that doesn't do it, pulling the lsu. The only other thing that's really changed recently is the fuser, supposedly had a revision due to an error code it was throwing but I don't have that bulletin handy at the moment.
        • jp74msj55
          • Oct 2014
          • 146
          I would bet a bad Primary Transfer assembly. I have had this issue a many of times.
          Replace and you should be good.
          • Luke123
            • Nov 2017
            • 22
            First question I have, is have you verified the image on the primary transfer belt is good? Also do not start to pull the springs longer first. I suggest to look at the are front and rear that move the secondary belt in and out, and make sure that are clean, and move freely. If that does not work, then maybe the secondary. Just seems to me that more trouble shooting should be performed before you wast money and time is just replacing parts.
            • ZOOTECH
              Senior member of CRS
              • 3375
              If you have another fuser, try replacing that - if no fuser available, check that the front and rear 'nip' are the same.
              • Ratchet2501
                • Mar 2017
                • 206
                The fuser was replaced recently but forgive my lack of copier experience but that doesn't seem like it would affect a single color without all four going to crap. Secondary transfer system is a sponge roller which seemed fine as far as movement and such. I am really thinking it's a bad connection but I have reseated the dv and drum (drum recently replaced) assemblies with no difference whatsoever.
                • ZOOTECH
                  • 3375
                  Sorry, I mis-interpreted the symptoms you described. If only the black is affected, than most likely the LSU and/or the shutter is causing the trouble.
                  • JoeK
                    • May 2017
                    • 21
                    Check the black pressure roller on the transfer belt. Without seeing the image issue, it sounds potentially like an issue that I had where one side of the pressure roller got knocked out of its slot causing that side to not add any toner to the pages.
                    • mojorolla
                      The Wolf
                      • 2598
                      F2-45 is a known issue on the Frontier machines. The ProCon sensor array gets warped, causing that specific code. Just had this on a 401 last week. Procon controls F and R registration and mono and color densities.
                      As to the light on one side, check the IT belt cam, known to break right off the frame. Also check the fuser bearings didn't fail or pop out.
                      • Ratchet2501
                        • Mar 2017
                        • 206
                        Fuser, transfer belt, drum assembly and developer are all new. Replaced the transfer belt today since I didn't see anything immediately wrong with it, still light on the left side. Going to hunt down the 64-5 prints and see if I can upload them since last time I couldn't and they haven't changed since all this crap started.
                        • spanky
                          • Sep 2012
                          • 468
                          See attached
                          • Ratchet2501
                            • Mar 2017
                            • 206
                            Originally posted by spanky
                            See attached
                            I could easily look past them not mentioning the mx-c312 but this talks about the ends going through not one side. I will scope it out when I'm digging around in it. Going to try re-replacing the drum and developer assembly.
                            • Ratchet2501
                              • Mar 2017
                              • 206
                              Mx-c312 645.pdf
                              Copy of the 64-5 B/W shows left side of sheet pretty much blank, readable but not very dark.
