Mx-3110n copy quality
  • Service@PRT
    • Oct 2016
    • 181
    Hi guys.. been trying to get copy quality to be good on this machine.. change developers, drums, cleaned lsu, cleaned scanning unit.
    Been done the simulation service sequence in changing developers and drums. From 25-02 up to 46-74... But still same copy quality problem.
    I've checked the transfer belt its clean and all good
    Heres the original... And the lighter one is the copy...
    Any inputs will be highly appreciated. Thank you!
    Every day of life is a learning process...
    Just make sure you are open in all aspects of comments.
  • mickj
    • Apr 2015
    • 33
    Re: Mx-3110n copy quality
    so this is a copy from the glass not a print
    if you change copy mode to manual exposure from auto is it the same ?
    • Service@PRT
      • Oct 2016
      • 181
      Yes tis one is from glass. Even in print is the same, i tried exposure as well like you said same output, even vice versa.
      Sent from my HUAWEI VNS-L21 using Tapatalk
      • mickj
        • Apr 2015
        • 33
        Can you list all the sim that you have done, and the order you did them
        • Service@PRT
          • Oct 2016
          • 181
          25-2 leave sim after, 44-2, 50-22, leave sim, 44-27, 44- 6 leave sim then lastly 46-74.
          • dsmith46
            • Oct 2016
            • 81
            How old is the primary transfer belt? It may look good, but they do lose the bright colors just from age. Just my two cents!
            Good luck!
            Dustin
            • mojorolla
              The Wolf
              • 2626
              If prints are good and only copies are washed, SIM 63, run the SIT chart and white shading adjustments with the proper calibration sheets.
              • igi
                • 1507
                Hi 46-74 service or factory? did you try both.
                make copy on single color, are they all washed out or not?
                Good luck.
                • Jamiesdad2
                  • May 2009
                  • 29
                  • Jhonjon
                    • Sep 2013
                    • 208
                    It's better to test another transfer unit from a running machine. Did you try to Misfeed and check if the image in the primary transfer belt is solid?
                    • OlliK1969
                      • Nov 2016
                      • 311
                      Hi
                      clean ccd and please clean the color registration sensor ( incl. gray field)
                      44-2
                      50-22 all near 0.0
                      44-6
                      44-26
                      restart
                      46-74
                      restart
                      • mickj
                        • Apr 2015
                        • 33
                        the sim I do on this model of sharp are and this order as above after some sim you after come out of sim mode and renter
                        61-13
                        61-11
                        50-22
                        44-02
                        44-27
                        44-06
                        44-26
                        46-74 Factory last
                        Hope this help
                        • Service@PRT
                          • Oct 2016
                          • 181
                          Good luck!
                          Dustin
                          Not sure how old tis one. But i tried it on another machine vice versa and its working good
                          • Service@PRT
                            • Oct 2016
                            • 181
                            Both are washed copy
                            • Service@PRT
                              • Oct 2016
                              • 181
                              61-13
                              61-11
                              50-22
                              44-02
                              44-27
                              44-06
                              44-26
                              46-74 Factory last
                              Hope this help
                              I tried with the 61... But no 61 - 13 and 11 on tis one.
