Sharp mx2700n
  • clark
    • Sep 2016
    • 109
    Sharp mx2700n
    just need to know if anyone knows which firmware is needed for a sharp mx2700n with the data security kit installed. Thanks
  • spanky
    • Sep 2012
    • 468
    Re: Sharp mx2700n
    If you print out a 22-6 it will tell you which data security kit is installed on the machine, that is the firmware you need.
    I don't have a manual on that machine so I can't tell you which kit is on it.
    • clark
      • Sep 2016
      • 109
      Re: Sharp mx2700n
      cant pull a report from machine. Someone removed hard drive. I replaced. comes up with code. I can go into machine 22-10 and see the security is there. I tried before I know it had the security installed to upload firmware and machine say wrong model. Thanks
      • ZOOTECH
        Senior member of CRS
        • 3375
        Re: Sharp mx2700n
        Look at the label on the EPROMs on the main pwb, it will tell the DSK model.
