MX-3050 F2-78 and "sensor calibration fr 06"
  • RascalMJ
    • Mar 2009
    • 174
    [Error Code] MX-3050 F2-78 and "sensor calibration fr 06"
    I have a bit of a troublemaker on my hands. I'll start with the short story hoping to get to the next step I can provide the LONG history tomorrow. It's almost 5pm and I am hoping to get some responses for the morning.
    Started as an F2-78 that kept popping up. I have checked all the bulletins/tech tips/this site and nothing seems to help.
    Troubleshooting led me to 5-22 and I get "sensor calibration fr 06". I cannot find anything on this error or any push in any direction.
    Any thoughts? It's a new machine that had some issues from the start that I can dig into later. Thanks for any quick suggestions to get me "over the hump"
  • spanky
    • Sep 2012
    • 468
    Re: MX-3050 F2-78 and "sensor calibration fr 06"
    Run a sky shot for each color and black to verify you don't have a problem with one of them.
    If they look good then clean the image density sensors that look down on the top of the transfer belt.
    Be sure the transfer belt is cleaned properly by the cleaning blade and not leaving any lines.
    If this is all good I would replace the transfer belt.
    After this rerun the 50-22.
    If that still fails go to sim 50-10 and reset the black data to factory settings, then go to sim 50-20 and reset the color data to factory settings.
    Rerun sim 50-22.
    • RascalMJ
      • Mar 2009
      • 174
      Rerun sim 50-22.
      Thank you so much.... I'm going to try some of this for sure when I get back to the office. I did replace those sensors {cleaned them prior as well} but no change. I also tried a new primary transfer.
      I didn't do so shots, but I've run many things through it that look great. Sharp Color eagle and other test prints.... Etc. Everything looks fantastic
      I don't think I did the sims 50-10 and 50-20 though. That may be the piece I was missing. I'll update soon, hopefully
      • mojorolla
        The Wolf
        • 2660
        Run SIM 46-74 and see if it fails with a DATA_SUB type error. If so, there are 2 retrofitted pressure springs that need to be replaced. The new machine IT belt are very poorly designed (no rubber edges inside the belt and no collars on the drive rollers). Original springs are so flimsy, the internal rollers will turn while the belt remains still. Original springs have 1 coil on each end, the retrofitted one have 2 coils on each end.
        • RascalMJ
          • Mar 2009
          • 174
          I believe that fails with a different error. Let me run and check....
          **yeah, that one is the one that just says "procon ececuting..." and just hangs up there.
          I did get it to print the the first patterns and read the print, but it hung up on the 2nd set without completing it.
          **EDIT # 2
          I just ran it again. It runs the copy bars fine, I place on the glass with 5 sheets of paper and it reads and prints out the boxes and says Confirm the adjusted patch and press ok. I hit ok and it prints the Printer portion of the bars and I scan with the extra paper and it reads it and says Confirm the adjusted patch and press ok.... then it just goes into a loop and doesn't ever finalize, just keeps saying "Confirm the adjusted patch and press ok", I hit ok and it says "Now registering the new target halftone procon, then Confirm the adjusted patch and press and Now registering the new target halftone procon ....wash rinse repeat.
          • RascalMJ
            • Mar 2009
            • 174
            That got me thinking, so I went into 46-24 separately to test how it went.
            Basically the same thing, it will print the bars, scan and print the boxes and say it is going to adjust, but never does, just loops into that message over and over.
            67-24 does the exact same thing. MAybe some kind of memory problem trying to save the adjusted values?
            • RascalMJ
              • Mar 2009
              • 174
              Tried replacing the PCU and MFP boards, but still the same symptoms. Many of the sims just give an error of "other". 50-22 gives "sensor calibration f 04 (or 06).
              I am running out of ideas. Is there a way to check and verify the 2 sensors (REGS_F/PCS_F
              REGS_R/PCS_R) on top of the primary transfer are working?
              44-6 engine half tone comes up "cl_sen_adj". I have looked everywhere for help, but most things point to an older cal style with the jig to solve, or a sim that is not in this model....etc. (troubleshooting has included replacing these sensors and the boards above....etc).
              Also, for what it is worth, the system prints beautifully. Sharp color Eagle and various other files we use to WOW customers...etc. I just can't get the F2-78 to clear for long, and as mentioned several sims error out...etc
              • HikingAK
                • Sep 2017
                • 13
                I had this issue twice, once with a MX-2610N & MX-5111N. Both times, I resolved the issue by cleaning the image registration/density sensors, then performing sims 44-2 & 46-74. (See page 9-27 in MX-3050N-4070N service manual.)
                Also, confirm that the sensor shutter is operating properly. Hope this helps.
                • Akitu
                  Legendary Frost Spec Tech
                  • Oct 2010
                  • 2595
                  I hate to be that guy, but surely you've tried replacing the registration density sensor? From the manual "If the error cannot be fixed, replace the image sensor
                  exclusive for registration."
                  • RascalMJ
                    • Mar 2009
                    • 174
                    Unless I'm missing something... Which is certain and likely the case. We have replaced the 2 sensors I am aware of for registration that rest above the primary transfer, one in the front and one in the rear.
                    REGS_F/PCS_F
                    REGS_R/PCS_R
                    Sent from my LG-LS998 using Tapatalk
                    • Akitu
                      • Oct 2010
                      • 2595
                      REGS_F/PCS_F
                      REGS_R/PCS_R
                      I just had to bring it up. I scanned this a few times to make sure it hadn't already been mentioned before I said something.
                      Your errors point more specifically to the front sensor. Have you checked your harness to ensure all pins are getting proper contact with the sensor? I've had some bad ribbon cables in these machines from the factory.
                      • RascalMJ
                        • Mar 2009
                        • 174
                        No, I appreciate it greatly. I'm still learning so I learn a lot from this board and people pointing out the obvious sometimes. Ha
                        I just told my office manager today I was out of ideas except possibly the wires\plug... Etc.
                        • Nachoman4life
                          • Oct 2007
                          • 212
                          Check the sensor target values for each color in sim 44-24, the values should generally decrease in value as the patch number gets higher. Messed up values ie.. K patch 13 is reading 100 when it should be in the 20-s to 30's will cause calibs to fail. if the values are out of whack I believe 44-21 will write new values. I had a mxm465 go double density on prts and copies, would also fail calibs, this fixed it for me.
                          Where the heck is my spring hook?
                          • RascalMJ
                            • Mar 2009
                            • 174
                            Awesome. Thanks. I'll have to verify. I think I tried that sim\clear the values but I'll check the values and try to clear as you suggest when I get in front of this machine again
                            • HikingAK
                              • Sep 2017
                              • 13
                              I faced similar issues on older models. What has worked for me is cleaning both image registration / density sensors, reset all settings to default values in sims 50-10 & 50-20, & verify the sensor shutters are operating properly & freely (had an issue with one of them not opening completely). Then run sims 46-74 & 50-22. Good luck!
