OSX job handling & authentication with adobe products
  • joe_vanacker
    • Dec 2016
    • 28
    Hello,
    does anybody have experience with pdf printing from mac?
    i have a problem when i want to use authentication or job retention in adobe products.
    when i open a pdf file and i print it without going further to the printer driver interface, the job retention or authentication is not executed.
    if i open the printer driver options without changing anything, then everything works.
    i would like that i only have to click print without having to click to the driver preferences.
    thanks for any replies.
    greetings
  • guitar9199
    • Sep 2016
    • 1097
    Re: OSX job handling & authentication with adobe products
    Originally posted by joe_vanacker
    Hello,
    greetings
    This is a walkthrough for Savin/Ricoh MFP's, but pretty much everything you need for configuring printing with Authentication is going to be listed here.
    Configuring locked print and adding user code (Mac to Ricoh) | Philosophy
    • joe_vanacker
      • Dec 2016
      • 28
      Thanks for the reply,
      i have done all of the above, but the problem remains.
      when i open adobe and i don't click through to the driver options of the printer, he does not authenticate or use job handling.
      once i've been to the driver options and i start a new print job, the job handling and authentication works for as long as the adobe program stays open.
      • mansart
        • 852
        once you set up the job by clicking through driver, have you saved as a preset?
        I see from one of the photo's it is set to TEST so I'm assuming yes.
        So you are say the next time you print with TEST selected authentication does not work?
        Try setting up a preset with another printer, with a different feature, duplex for example
        If that preset does not hold either, I would say you have a MAC issue not a machine driver issue.
        Have you tried resetting print system on the MAC?
        macOS Sierra: Reset the printing system
        • joe_vanacker
          • Dec 2016
          • 28
          hi,
          yes i saved it as a preset, i will try it with a different printer and get back to you.
          i've tried it with different mac's and they produce the same issue.
          regards,
          youri
