MX-2640N Static display panel
  • Jammed
    • Jun 2015
    • 33
    [Electrical] MX-2640N Static display panel
    The op panel is like an old TV set when it goes off air. Very colorful static lines fill the display screen.
    Replaced the op panel PCB, no change. Replaced the 5V PCB under the op panel board and the screen goes black and stays black. Only thing left is the scanner board on the copier rear wall... ?? Any ideas? TIA
    -Steve
  • boutn
    • Jun 2016
    • 540
    Re: MX-2640N Static display panel
    -Steve
    had this once, think it was...bad SDcard...as usual.
    • moose55
      • Mar 2017
      • 143
      Try reseating the connection between the MFP PWB and the mother PWB.
      The Moose is loose!!
      • mansart
        • 852
        Turned out to be MFP Brd.....
        1. Screen would display static pattern, however would work, the button mapping remained intact.
        2. When you remote into machine via VNC the remote image would display correctly
        • copierdude1114
          • Dec 2015
          • 29
          I had that problem before, but I was ale to get into the web interface and update FW. And it fixed the issue.
