Tray 2 Lift Motor
  • MFPs R Now PCs
    MFP Tech & I.T. Manager
    • Jul 2011
    • 156
    [Misc] Tray 2 Lift Motor
    We have a Sharp AR-M257 that continually lifts and drops Tray 2 over and over. Isn't there a way to fix this without replacing the lift motor like stretching the springs in the tray or bending the little metal tabs in the tray. I swear there is a trick to fixing this with replacing a part. Any thoughts? Thanks in advance!
    It does not matter how slowly you go as long as you do not stop. –Confucius
  • ZOOTECH
    Senior member of CRS
    • 3375
    Re: Tray 2 Lift Motor
    Sorry, I don't remember the p/n, but the tray lift assembly has a gear that looses a tooth or two, and causes these symptoms.
