MX-5070 C1-07
  • moose55
    • Mar 2017
    • 143
    MX-5070 C1-07
    Anyone else having problems with the yellow charger cleaners? Sharp seems to know the problem exists (tech pub stating the problem), but I have yet to find a solution to the couple I have out that consistently throws this code. I have replaced the PCU, the cleaner motor, the sensor, and the sensor actuator. Sharp has said that there is a burr in where the actuator slides. I have cleaned it all out along with putting a new actuator in with no luck. The actuator slides smoother than the other 3 colors. I honestly don't know where else to go on the problem? Has anyone come up with a solution yet?
    The Moose is loose!!
  • mansart
    • 852
    Re: MX-5070 C1-07
    Pull out the yellow developer unit and look at the cover just above mag roller.......it probably is sitting higher on the rear side. Take cover off and remove some of the foam seal re seat and make sure it is sitting flush, just as the front side does.
    This has taken care of issue for me.
    • mansart
      • 852
      Re: MX-5070 C1-07
      This is not isolated to the yellow dv unit, can happen with all.
      When the MC cleaner moves it is bumping into the DV cover.
      • mansart
        • 852
        Re: MX-5070 C1-07
        TIMEOUT.....
        Sorry the cover in question is just below the mag roller. Sorry, it all blends into one big problem after a while..... Here is picture
        • spanky
          • Sep 2012
          • 468
          Re: MX-5070 C1-07
          See attached bulletin
          • sck
            • Mar 2009
            • 20
            Re: MX-5070 C1-07
            We have turned off the charge cleaner for now until sharp fix this .
            in sim
            Disable Corona Cleaner
            SIM 44-28 MC_CLEAN_TIME to a "0"
