Blank display on 3050/4070 models.
  • Bgorby
    • Jan 2018
    • 7
    Having trouble getting the display to work on two machines. Pretty sure the problem is with the CN33 connector on the MFP/SCN PWB.
    Reconnected numerous times. The home light comes on The error LED is on display remains blank. Any ideas?
  • jp74msj55
    • Oct 2014
    • 149
    Re: Blank display on 3050/4070 models.
    SD card? Seen this alot on this site for that issue.
    • driving lots of miles
      • Jun 2016
      • 398
      I would agree with the card but I believe this machine has the Msata card instead of the SD card
      • harleyrider
        • Oct 2011
        • 348
        check TT-102517_2 probably bad mSATA.
        • bilyahn
          • Dec 2006
          • 1470
          We have 11 of these units and 5 of them have had bad mSATA cards!
          Good luck.
          Bil
          • Bgorby
            • Jan 2018
            • 7
            Okay! Will try MSATA.
            • bilyahn
              • Dec 2006
              • 1470
              Just to let you know, when the mSATA goes bad the display is dark and the power indicator light (small green light next to power button) flashes. Have had a bad mSATA give E7-80 and 90 codes also prior to it failing..
              Good luck.
              Bil
              • Bgorby
                • Jan 2018
                • 7
                I have tried an Msata , still no display.
                • niceville318
                  • Feb 2014
                  • 43
                  I had a similar problem but replacing the mSata fixed it. take a look at page 7-39 in the service manual. It may help you isolate the problem.
                  Oops, I just realized the Tech Tip earlier addressed this...
                    • Jun 2016
                    • 398
                    I am going to have to get some Msata preprogramed. We are getting more of these machines out and haven't had any issues yet but if they are having the same issues as the SD cards I had better be prepared.
                    • Luke123
                      • Nov 2017
                      • 22
                      One thing you can try, is put the machine in a CN update. if the screen comes on, then not your ops, or the LVDS pwb. Since you did the SATA, then the next step is the MFP/SCN PWB. good luck.
                      • mansart
                        • 852
                        Going into Emergency Firmware to check panel is a great trick, however beware that the Emergency Firmware switch when turned on.....bypasses the On/Off switch on panel of machine.
                        Learned this the hard way.
                        • bhangdu
                          • 16
                          hi,
                          I had a similar problem before. after replacing mfp-scn pwb & lvds pwb problem fix.
                          • Bgorby
                            • Jan 2018
                            • 7
                            We had three machines with similar problems.
                            Two were just CN33 not getting "seated properly".
                            The third does have bad MFP/SCN and mSATA PWB's.
                            I would like to thank everybody for your support.
