Full Bleed Stripes 3570
  • OperatorError
    • Aug 2017
    • 21
    I peeled one of these bad boys off my customer's fusing unit. They had 2 or 3 samples but I wasn't able to duplicate it. Print not copy. The pattern and variety of colors make no sense to me. Perhaps high voltage board? Anyone seen this?
    Thanks in advance.
    Uploads are failing on this site so here is a link
    fullbleed — imgbb.com
  • copiertec
    • Jan 2016
    • 2188
    Re: Full Bleed Stripes 3570
    I always start at AC voltage from the wall and work to the copier, check ac wall voltage and check for proper ground.
    • mansart
      • 852
      Wow.... can't wait to see the answer to this one.
      Is this striping pattern continuous on the primary transfer belt?
      Does a BW copy/print come out OK?
      • mansart
        • 852
        Just re-read post......problem is not consistent.
        Are all the samples provided by customer a result of a jam? Or do any of them exit?
        • OperatorError
          • Aug 2017
          • 21
          The picture is one that exited. I think 3 exited and one wrapped around the fuser. When i arrived the stripes were on the belt but cleaned off when I ran it and could no longer duplicate.
