mx-3070n
  • dcooper
    • Nov 2014
    • 37
    mx-3070n
    How do you clone a msata chip?
  • bilyahn
    • Dec 2006
    • 1455
    Re: mx-3070n
    Sharp MX-M365N Corrupt SD Card
    Here is the link for program and guidelines. Pretty straight forward. You will need a good mSATA to start with and you can save the file to your computer. Then rewrite as many as you need. mSATA are series specific by this I mean you can not take a MX3570 chip out and put it in a MX5070, it will not work without writing the correct firmware, but you can rewrite the MX3550 with a 5070 information and it will work just fine. Interestingly you can take a 4070 chip out and use it in a 6070 with no problems even thought they are listed as different part numbers. Be sure to do a firmware update as soon as you replace the chip.
    Good luck.
    Bil
    • lenovos
      • Oct 2012
      • 137
      Re: mx-3070n
      I had a clone go bad and I have a little bit of a problem with a MX-3070v. Something must have been corrupt the first time that I tried it. The copier boots up and I can make copies but I cannot get to the web page, If I push settings on display it just says please wait. the copier is on dhcp but I can not log into it.
      When I first booted the machine it came up with a U2 60 which is watermark I tried updating firmware and machine said that I had a bad file
      I down loaded a new file and tried updating one file at a time Machine would not reboot after that. I now have the copier up but I cant get to web page or any of the settings. I can get to simulation In firm ware top bundle 000000 and bottom bundle is 000000
      • doyvid
        • Aug 2019
        • 56
        Re: mx-3070n
        Replace the hard drive. Just had similar issue today u2-05 and e7-93, unable to go into settings, print 22-6 or login to webpage (said invalid password). After hdd changed password and everything else worked again.
        Not sure about your firmware issue since that is stored on the SSD I think. Could try emergency firmware update with dip switch on board.
        • DAKOTADAN
          • Jan 2011
          • 60
          Re: mx-3070n
          Download the most current firmware from Sharp and do a CN firmware update on your machine, this type of download has fixed some really
          goofy problems for our service Techs,. Good luck Dan,
          • lenovos
            • Oct 2012
            • 137
            Re: mx-3070n
            Update reformatting hard drive solved most of the problems. can now print and use settings on display.
            • lenovos
              • Oct 2012
              • 137
              Re: mx-3070n
              Tried that and did not help. A friend suggested swapping hard drives and that solved most of the problem. Everything seems to work but it still says bundle 000000000000 under firmware version. next to serial number.
              • DAKOTADAN
                • Jan 2011
                • 60
                Re: mx-3070n
                I have seen a firmware up date give all zeros on a upgrade, and it took 2 more CN update tries to get it to upload all of the package, I also should
                mention that anytime you upgrade firmware, I unhook the network and fax cables, and never open any doors on the machine while the up grade
                is loading. It may give errors on the upgrade at the end.
                Also since I am getting old and forgetful, I put my car keys on top of the network cable so I can't leave with out plugging the cables back in.
