Sharp MX 6000
  • Reed
    • Feb 2011
    • 259
    Sharp MX 6000
    This machine was getting color streaks on the page so I changed all the drums and secondary transfer belt because it was ripped. After finishing the copies are now coming out with gray shadows. It will get better and worse at times but it generally stays about the same. I have attached a sample of what it is printing.. Thanks in advance SPoloni Law18070208040.pdf
  • ntbann
    • Jan 2012
    • 627
    Re: Sharp MX 6000
    It looks like it needs to be calibrated.
      Re: Sharp MX 6000
      Originally posted by Reed
      This machine was getting color streaks on the page so I changed all the drums and secondary transfer belt because it was ripped. After finishing the copies are now coming out with gray shadows. It will get better and worse at times but it generally stays about the same. I have attached a sample of what it is printing.. Thanks in advance [ATTACH]39994[/ATTACH]
      does sharp have a defect ruler in the service manual? if so check distance between marks... frankly it looks like Dev unit! did you calibrate after installing PCUs?
