NX-4110 scanning Checks
  • xring1958
    • 166
    I have a customer that claims all she scans are checks and that they are now having issues.
    The machine says check original cancel job. They say this is a new issue
    I am assuming that there is a security feature printed on the new checks that is preventing the scan job.
    She stated that some checks work and some are not allowed
    She also says the older MX-5001 still allows her to scan all of them.
    This seem logical since the newer machine may be more secure for some originals.
    I have heard that if you scan in Black & White it will be allowed but she said that doesn't work.
    I have also heard that enlarging or reducing may allow them to scan.
    Any insight is appreciated.
    • 22808
    Re: NX-4110 scanning Checks
    that is correct .. scanning Checks - Money - Bearer Bonds - ect the newer machines have a security feature ... USUALLY scan/copy in BLACK and slightly enlarging will solve the problem.
    May I suggest you research a little ( usually in USERS manual ) and then be on site to walk your customer through the process. I'm NOT sure ( doubtful ) if that feature can be turned off on that unit.
    • copiertec
      • Jan 2016
      • 2172
      Agreed with Phil B. Copy only in mono and/or slightly reduced or enlarged.
      • austonrush
        Sharp & HP Tech
        • 233
        I can confirm on the newer MX4071 that scanning in Mono resolves the issue!
        • JLSam
          • Jun 2015
          • 601
          As long as it doesn't have the EUrion Constellation, or the rings are blocked.
          Please see: EURion constellation - Wikipedia
          OR
          It doesn't have Anti-Copy Floil, Holograms, and Seals.
          • repn1999
            • May 2010
            • 310
            you are running into counterfeit protection not allowing the job. basically it makes you scan/copy in black and white(Mono2) and at least 10 percent larger or smaller than the original. this protection scheme differs slightly from series to series but thats a basic thing that seems to work. I also believe enlarging/shrinking past 10 percent will allow color to be used as well. some of my customers have said using a sheet of paper on top of the checks helps.
