MX-3100 Stored documents password protected and can't delete
  • Doug James
    • Jan 2012
    • 935
    [Misc] MX-3100 Stored documents password protected and can't delete
    This customer has documents stored in document box the when you highlight asks for a password. This was left by an employee that was fired. I tried to do an image clear and that did not have an effect. Been all through the manual and can't find the answer. Thanks so much for any help !!!
  • mttech
    • Mar 2014
    • 127
    Re: MX-3100 Stored documents password protected and can't delete
    Try sim 62-11 to delete document filing data. Be aware that this will delete all of the documents. I would recommend to print out the ones you don't want deleted so you can rescan them back.
    • mansart
      • 852
      Also you can.......
      1. login to web interface
      2. System settings
      3. Document Filing Settings...... once here in main window under Administrator Authority Setting..... select Delete File
      This will give you ability to delete protected files when logged on an admin
      • mickj
        • Apr 2015
        • 33
        As what was said above this way you can remove just the ones you need to
        • Doug James
          • Jan 2012
          • 935
          Thanks you guys so much !!! Worked like a charm !!!
