Sharp mx c3140 ADF jams
  • 1stcavvet
    • Apr 2015
    • 231
    [Jamming] Sharp mx c3140 ADF jams
    The 1st page thru this ADF jams-------stops as it leaves the slit glass to exit, and bunches up. If you remove it and start again the machine will run all day till it's left to sit for awhile again. I'm thinking there's a motor (probably magnetic style) that is sticking when the machine sits awhile. It never ever jams after you remove the 1st page jam no matter how big a pack your scanning, or how many people use it in a row------ leave it sit 15-20 minutes or so and the 1st page will jam. when it jams it's always the same place as it leaves the slit and goes backup into the feeder.
  • DAKOTADAN
    • Jan 2011
    • 59
    Re: Sharp mx c3140 ADF jams
    Check your ADF hinges to see if they are loose or a spring maybe pushing the ADF off the slit glass after it sits still for awhile. I know they have updated the hinges on this series since the machine came out. I like to start with the easy fixes first. Good Luck Dan
    • 1stcavvet
      • Apr 2015
      • 231
      no!!! it makes it past the slit glass and sorta crumples up in the throat of the exit. like it's crashing into dead rollers. after that initial jam it'll run like a champ as long as it's not a long while till some one uses it. that's why I thought there might be a separate drive for the ADF exit ( from an inch or so past the slit glass on out.)
      • mojorolla
        The Wolf
        • 2550
        If the jam codes are SPPD3 variants, pull the sensor and flip over the plastic bracket it sits in. There is a "dampening pad" under the actuator flag. Over time, this becomes a "why the hell is this sticky things here" pad. It slows or stalls the flag from returning in time.
        • 1stcavvet
          • Apr 2015
          • 231
          Can you get to the sensor by pulling back the platen cover and get to it from the bottom??? and thank you very much with all the printer solenoids and flags I have to repair I never thought of a sticky sensor flag Thanks
          • driving lots of miles
            • Jun 2016
            • 378
            Yes you can get to the pad from the bottom of the ADF, just had this issue today. We ended up removing it completely.
            • 1stcavvet
              • Apr 2015
              • 231
              thanx again
              • mojorolla
                The Wolf
                • 2550
                Another symptom of the sticking sensor is the lead edge will usually be off. The timing of the sensors control the timing of the scan. If the sensor sticks, the entire image usually shifts towards the trail edge due to sensor signal being late.
                  • Jun 2016
                  • 378
                  ours was just a 1/2 inch blur in the middle of the page.
