Sharp MX-2640N Scanning via SMB to Windows 10
  • MFPs R Now PCs
    MFP Tech & I.T. Manager
    • Jul 2011
    • 156
    [Misc] Sharp MX-2640N Scanning via SMB to Windows 10
    It does not matter how slowly you go as long as you do not stop. –Confucius
  • JLSam
    • Jun 2015
    • 601
    Re: Sharp MX-2640N Scanning via SMB to Windows 10
    2640 can scan up to Smb v2 with the latest special firmware that was released last year. Smbv3 is available for some models, not all.
    Special Firmware
    Models:MX2640N / MX3140N / MX3640N
    Release Type:SpecialROM Control: N/A
    Release Date:July 2017File Name:Aries2_Combi_0600A2B0_A.zip
    Versions:
    Special Firmware for SMB2 Client Support
    Version 0600A2B0_A
    Sent from my ONEPLUS A5000 using Tapatalk
    • mickj
      • Apr 2015
      • 33
      just enable smb1 on the win 10 pc
      Go to Control Panel > Programs and Features > Turn Windows Features on or off > check or uncheck the box for "SMB 1.0/CIFS File Sharing Support"
      • mickj
        • Apr 2015
        • 33
        To change the FTP port number
        Go to Security Settings port control and change the FTP port there
        • JLSam
          • Jun 2015
          • 601
          I would not recommend to enable SMB v1 due to the exploitable vulnerability of the NetBios port, responsible for many of those Ransomware WannaCry attacks.
          • NAZI
            It is not from the Sharp Copier it is from Windows 10 last update.. they blocked the scan to file (SMB) security reason!!!!
            If you can enable it from your PC it will work but you need a good IT guy to do it so..
            Good luck..
            Thanks,
            • MFPs R Now PCs
              • Jul 2011
              • 156
              Thank you however we did check this prior to post and there is nothing there to edit the FTP port, only enable/disable. There is port control for FTP Print though but that not it right?
              • MFPs R Now PCs
                • Jul 2011
                • 156
                Good luck..
                Thanks,
                Thank you, yes you are right that SMB 1 has been deprecated in Wndows 10, however we can scan to same Windows 10 PC from brand new Lexmark copiers. SMB 2/3 is enabled by default in Windows 10, but the copier has to be using a high enough version of SMB.
                  • 22808
                  UMmmm EXCUSE ME.... windows removed SMB1 due to security issues. IF you enable SMB1 you could be putting YOUR company at LEGAL risk if any virus/malware gets into that companies systems.
                  not a smart move.
                  • MFPs R Now PCs
                    • Jul 2011
                    • 156
                    not a smart move.
                    Yes, we agree here too. For anyone reading through this post, please DO NOT turn on SMB 1 on a Windows PC, ever. If ANYTHING happens you could find yourself in a lawsuit. Use something like Filezilla and FTP (change the port number to a high random number - just google whats available - also use a username/password. This will lock the FTP server down somewhat and prevent someone browsing in via anonymous and seeing there scanned files)
