MX-M565 Freezing
  • copierwhisper
    • Mar 2013
    • 78
    MX-M565 Freezing
    MX-M565 Freezing. After performing memory test and HD test the machine continues to lock up, any thoughts on where to start?
  • mojorolla
    The Wolf
    • 2627
    Re: MX-M565 Freezing
    This model had a known issue of the machine freezing or becoming unresponsive due to a failing low voltage power supply.
    Also, remove and open the op panel. I had one a few month back that one of the solder points was rolling around inside, intermittently locking the machine.
    • dsmith46
      • Oct 2016
      • 81
      The SD cards are known to fail as well, causing lock up issues.
      Good luck!
      • copierwhisper
        • Mar 2013
        • 78
        Thank you for the reply's- I'll investigate further based on your input!
