Help finding a fan
  • jonathan3205
    • Apr 2016
    • 30
    Help finding a fan
    Hi, I have a MX5001N, and need to replace the TN cooling fan part number FANP0112FCPZ to solve L4-57 error, but I can't find it anywhere. The label says nidec d04r-24th-47b. Do you have any idea where can i get it? I'm in Mexico and the only SHARP approved support center does not have it available.
    Here are some pics of the fan for reference.
  • r3d343420
    • Aug 2012
    • 55
    Re: Help finding a fan
    NFANP0112FCPZ - Sharp MX-4100 Fan Toner Cooling Item Inc.
    Sharp MX-5001N Toner Cooling Fan, Genuine (M6104)
    Couple places I found searching sharp 5001 toner cooling fan instead of using the part number
    • ntbann
      • Jan 2012
      • 628
      You can repair that fan if you are in a bind. Peal the sticker off and use a pick to get the little clip off. Then clean and re-grease bearings and put back together. It will get you by for a bit.
