Mx 7090 card reader issues
  • yorky
    • Jan 2013
    • 6
    Hi All
    I've been asked a question by one of our support to be honest I haven't come across this issue so I thought I'd throw it out there
    MX7090 using paper cut and a card reader doesn't validate the card when the user swipes the card in energy save mode apparently the theory is that it drops the first 2 digits of the card
    Anyone out there in copier land come across this issue
    thanks in advance
    Yorky
  • mansart
    • 852
    Re: Mx 7090 card reader issues
    Have not seen this but you may want to change "Sleep Mode Power Level".
    There are two options 1)Low Power (which I believe is default) and 2)Fast Wake Up........try "Fast Wake Up" to see if that solves issue.
    Purely speculation, based on 0% real world knowledge of this problem.
    • harps05
      Field Service Engineer
      • Mar 2012
      • 110
      Any udpate on this one Yorky.
      Did you try the power management setting mentioned above? We have a customer with a similar issue.
      • repn1999
        • May 2010
        • 310
        I would also suggest turning off the turn panel off while in preheat/sleep mode option. I did see this issue on a couple 7040 machines but it ended up being an issue with the combination of reader hardware/software version and type of cards being used. That could be your issue as well since the time I saw it the client was also using papercut.
        • igi
          • 1507
          Hi
          It is recommended to update the mfp software with the card reader attached.
          Good luck
