Setting up user accounts on an MX-2640
  • lenovos
    • Oct 2012
    • 140
    Hi I am setting up user accounts on a MX-2640 , The copier will not allow me to scan unless I sign in as an administrator. if i push the hdd file retrieve the buttons are blank.
    If i sign in as administrator the buttons are what they should be. I think that the user has full rights under their authority group.
    Thanks in advance.\
  • mansart
    • 852
    Re: Setting up user accounts on an MX-2640
    Double check "Authority Groups"
    Something in the rights of the User vs. the Admin
    • lenovos
      • Oct 2012
      • 140
      Hi I have enabled everything that I can find, I know that I am missing something. I think that i have enabled everything on the list.
      • mansart
        • 852
        Create a new "Authority Group"
        "Select the Group Name to be the Registration Model"....... use drop down to select ADMIN
        Under "Users" change his/her Authority Group the the newly create group. Does it work now?
