MX-M1204 misfeed in finisher FSS203_N
  • Dewald
    • Feb 2015
    • 15
    [Jamming] MX-M1204 misfeed in finisher FSS203_N
    Hi I have a Jam occurring in the FN22 when doing saddle stitch copying. Happens at sensor FSS203_N. First booklet goes thru and jams on second booklet.
    Can anyone tell me if there is a tech-bulletin on this or whats causing this problem.
    Re: MX-M1204 misfeed in finisher FSS203_N
    what is jam code?
    what have you done to correct the issue?
    do you have the manual?
    • chubblies
      • Jun 2011
      • 154
      Its the FSs203 sensor 0CWFK21772001. Replace it and the bracket that it attaches to as well as it is very critically angled, and Sharp have adjusted this angle slightly with the new bracket because of this issue.
      0CWFC876140// is the part code of the bracket (it is not in the parts manual)
      • copierdude1114
        • Dec 2015
        • 29
        Clean the black rubber roller that the sensor is facing, it gets heavily saturated with paper dust.
        • boutn
          • Jun 2016
          • 547
          Did you ever fixed this?
          I'm having the exact same problem right now...
          • boutn
            • Jun 2016
            • 547
            ordered the 0CW4G85141001, swapped it, and problem solved!
            • BSimp
              • May 2022
              • 2
              Is there a tech bulletin mentioning the change of angle to the bracket? I only found the one on the new sensor. Put in the new sensor and cleaned rollers, machine will make 11x17 booklets just fine but every time we run a 8.5x11 booklet it jams on the second booklet. Paper stops right at FSS203. Thanks.
              • Prints Charming
                • Aug 2019
                • 189
                Also keep in mind the Saddle Control Board has had numerous updates over the years, about 4 versions I recall. I've had the FSS203_N be caused by the sensor already mentioned, but also had 2 of them fixed with an updated Saddle Control Board (right next to the sensor). Firmware on the MXFN22 for Main and Saddle is critical as well. Sharp have released some special versions/running changes over the years for Saddle or Staple problems.
                • BSimp
                  • May 2022
                  • 2
                  Thank you! Firmware is up to date, we have ordered a saddle pwb and will see if that works!
                  • chubblies
                    • Jun 2011
                    • 154
