MX-3110N error Code F6-00
  • KirkG
    • Jul 2017
    • 12
    [Error Code] MX-3110N error Code F6-00
    I first got a E7-91 HDD error and replaced HDD. Then I got a U2-60 error and went back to install the watermark.
    Now I've got a F6-00 error. I replaced the Fax kit and still cannot get it to clear. What can you tell me?? anyone?
  • JLSam
    • Jun 2015
    • 605
    Re: MX-3110N error Code F6-00
    Have you tried reflashing production firmware after the watermark?
    Sent from my ONEPLUS A5000 using Tapatalk
    • KirkG
      • Jul 2017
      • 12
      no I haven't ...thanks I will give it a try.
      • copiertec
        • Jan 2016
        • 2222
        Agreed, with JLSam, try re-flashing the firmware being you have tried a different fax kit. Did you try a different Fax Rom when you changed out the fax? Because, a bad fax rom will cause issues as well.
