MX-4111N has yellow out put only
  • Ray Gates
    • Aug 2013
    • 33
    [Misc] MX-4111N has yellow out put only
    I have a MX-4111N that only puts yellow on copies/prints. If any other color is selected then it will output blank paper. Machine has nearly copy count of 1,000,000. I am leaning toward either a LSU unit or PCU-PWB.
    What think you all?
    Re: MX-4111N has yellow out put only
    What think you all?
    I THINK you left out a lot of information regarding the problem.
    1,000,000? what are the life counts on Drums/Devs etc? what have you done to it? Have you checked/cleaned contacts on consumables?
    you really need to give us more information to work with.
    • dsmith46
      • Oct 2016
      • 81
      I would check the LSU shutters to be sure they are opening correctly. I've had them stick once on a very similar machine, and only the Yellow shutter would open, all others would stay closed.
      Good luck!
      • boutn
        • Jun 2016
        • 547
        Good luck!
        Indeed...had a few of these.
        Best clean the solenoid which opens the shutters (sits behind the LSU-unit), remove all shutters and clean the machine.
        Should be fine after that.
        • ntbann
          • Jan 2012
          • 628
          If i remember correctly there is a bulletin to remove the shutters.
