MX-2630 with FX-15 will not auto receive faxes
  • dacjkhadley
    • Mar 2013
    • 19
    [Misc] MX-2630 with FX-15 will not auto receive faxes
    They had a MX-2600 with a FX-02 that will pick up with no issues. When you dial the number, the line rings twice then on the third ring, the tone changes and the FX-02 will pick up on the fourth ring. The FX-15 will not, the line light intermittently lights when the third ring starts but you do not hear the whole ring, just a part of it and the line light will go out but come back on when the 4th and so on rings but will not stay on or connect. I have let it try to connect up to 15 rings. I hope this makes sense. I have called Sharp and they recommend replacing the FX-15. Just want to know if anyone else have experienced this. I have changed the soft switches to what Sharp recommended but still NG.
    Re: MX-2630 with FX-15 will not auto receive faxes
    double check incoming fax settings vs both machines
    • dacjkhadley
      • Mar 2013
      • 19
      Yeah, all settings are identical. Have to wait for the updated FX15 cable as my office sent an old style unit.
      • OlliK1969
        • Nov 2016
        • 310
        Hi
        SIM 66-1 switch 9 bit 7 from 1 to 0
        or
        SIM 66-1 switch 8 bit 8 from 0 to 1
        It works by problems in germany @ this model
