MX-5112N
  • swagreis
    • Jun 2008
    • 92
    MX-5112N
    I have an error message on simulation 50-22
    "Sensor calibration error fr-06"
    Pls advise what to do
    The color can be seen each color alone
  • bilyahn
    • Dec 2006
    • 1470
    Re: MX-5112N
    Did you try to run the simulation again? Drum sensor issue maybe just clean and retry. The manual is not clear on cause of this code or even what the code is.
    Good luck
    Bil
    • swagreis
      • Jun 2008
      • 92
      Re: MX-5112N
      Which drum may cause this error
      This sensor in drum unit or in machine
      Thank u
      Sent from my SM-N9005 using Tapatalk
      • bilyahn
        • Dec 2006
        • 1470
        Re: MX-5112N
        Looks like you have several issues going on here. Black drum definitely and possibly the primary transfer belt. What's the copy count and PM percentages.
        Good luck.
        Bil
        • swagreis
          • Jun 2008
          • 92
          Re: MX-5112N
          I changed primary transfer belt
          • swagreis
            • Jun 2008
            • 92
            Re: MX-5112N
            • OlliK1969
              • Nov 2016
              • 315
              Re: MX-5112N
              Hi
              MX-5112 Transferbelt Unit MX-510U1 !!!!
              MX-3610 Transferbelt Unit MX-230U1
              Have you taken the right on????
              • swagreis
                • Jun 2008
                • 92
                Re: MX-5112N
                Just trying with mx-5000n
                • OlliK1969
                  • Nov 2016
                  • 315
                  Re: MX-5112N
                  MX-5000N is MX-410U1 !!!!!
                  • Jhonjon
                    • Sep 2013
                    • 208
                    Re: MX-5112N
                    I think you need to replace all the consumables... And perform color calibration.
