Sharp MX M363N firmware - need help please
+ More Options
Posts
  • skibum
    Independent Service Tech
    • 231
    Can someone send me the latest firmware for the Sharp MX M363N. Scan to email has been lost and this is all I can think of. It functioned for years and no changes were made that we know of?
    IT has already setup another email server that functions fine from Canon and Konica mfp equipment on their network. I would like to resolve this as the IT professional can not resolve it at this point.
    Thanks in advance for any offer of help.
  • guitar9199
    • Sep 2016
    • 1100
    Re: Sharp MX M363N firmware - need help please
    You might also want to specify whether or not your machine has the Data Security Kit installed. That's different firmware than what's on the base machine, and it'll save you some time at the customer's location by NOT bringing the wrong firmware when you arrive!!
    ...don't ask me how I know.
    • mansart
      • 852
      What are you getting for an error when you try to send?
      • Drummer
        • Feb 2013
        • 46
        PM me your email and I can send it to you.
        Special firm. came out in Oct 2017 for scanning issues
        • skibum
          • 231
          I am not sure if this has the data security kit installed as I am not their currently and we did not provide this machine. My email is altcopy@comcast.net
          Thank you!
          • skibum
            • 231
            BTW when sending the message on the status says OK, as if it was sent to the email successfully.
            • ntbann
              • Jan 2012
              • 628
              Then it sounds like its an authentication issue to me. Is it office 365?
              • skibum
                • 231
                Yes it is a problem with scan to email using Office 365. Scan to folder is ok.
                  there are quite a few threads here @ CTN that covers the 365 issues.
                  • Ben Around
                    • Apr 2012
                    • 151
                    I'll second the idea that it's probably not the firmware.
                    Office365 will allow you to connect but not allow attachments to go through if your email setup is incomplete. For example, you can get it to pass the connection test, and you can send the meter information. But you cannot get scanned documents to go through.
                    Someone posted the bulletin the other day on here that outlined all the required entries. Sorry I can't find it right now.
                    Make sure the reply to: email address, admin email address etc. are all (populated) the same as the authentication email address.
                    Wish I could be more help, I just don't have the time right now to dig it up. I just wanted to encourage you to work on the email setup information vs the firmware.
                    P.S. make sure ssl is enabled
                    • Demon33
                      • Jan 2019
                      • 38
                      If the issu is from security "tls 1.2" I have tried all I can to make it work without success and sharp is not going to release another firmware for that model.
                      Yes there is technical tips (see attachement) to help you but I did not manage to make it work.
                      Ask if you have more questions
                      • bandula
                        • Oct 2013
                        • 6
                        Originally posted by drummer
                        pm me your email and i can send it to you.
                        Special firm. Came out in oct 2017 for scanning issues
                        can you pls send me the firm ware for mxm 363n
                        my e mail is [ bandula78@gmail.com ]
                        thank you
