MX-5141 dropping off network
  • dwarf
    • Oct 2012
    • 168
    [Misc] MX-5141 dropping off network
    we have a customer who has 3 MX-5141's that they suddenly can not print to ...they keep dropping internet access...sometimes you can ping them and then suddenly you can't...the machine will sit idle for hours and then suddenly fire up and print out a blank page...
    I forgot to add that none of the customers other printers are acting up..they all work normally...only the Sharp machines are having the problems staying on line...
  • D_L_P
    Self Employed
    • Oct 2009
    • 1196
    Re: MX-5141 dropping off network
    Definitely odd all 3 would suddenly have this issue. Is it possible all 3 have the same hostname? That would be equivalent to having the same IP addresses.
    Look in Network Settings> Quick settings> Device name
    If they are all named MX5141N, just add a # or letter at the end.
    • NeoMatrix
      Senior Tech.
      • 3513
      Leaning towards corrupt print queue... Delete all files in the spooler directory.
      There is a lot of previous threads relating to Sharp Connectivity...
      Google Search CTN:
      "site:wwww.copytechnet.com Sharp Network"
      Random:
      MX-M503n losing network connectivity?
      HTH
      • mansart
        • 852
        Under security settings..... disable all ports that are not in use
        Are these POE lines? if so place an inexpensive 5 port hub (switch) between machine and network
        Under Energy Save settings change wake up settings to "Fast Wake Up"
        Change network speed from Auto to 100 mb/s
        • xordi69
          • Jun 2010
          • 200
          Good solutions from Mansart, and upgrade firmware.
          • mojorolla
            The Wolf
            • 2627
            SIM 55-3, switch 6 set bits 1 - 8 as below:
            10010000.
            Try removing from network and printing directly, does issue still happen? Any error codes in the job log?
            • boutn
              • Jun 2016
              • 547
              10010000.
              This is the second time i have seen this sim...
              What does it do exactly? something to do with network speed?
              And what are the settings?
              • mojorolla
                The Wolf
                • 2627
                It set the network speed, or to auto negotiate, and duplex speed.
                SW6-1 Auto-Negotiation
                0 = Enabled
                1 = Disabled
                SW6-2: Link Speed (when auto-negotiation is Disabled)
                0 = 100Base TX
                1 = 10Base T
                SW6-3: Duplex Mode (when auto-negotiation is Disabled)
                0 = Full
                1 = Half
